Filter SA messages to determine which SA messages to accept from a peer and which SA messages to send to a peer. By default, no inbound or outbound filter exists.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#ip msdp sa-filter in 21.0.0.2 route–policy helloworld
Variable definitions
The following table defines parameters for the ip msdp sa-filter command.
Variable |
Value |
{A.B.C.D} |
Specifies the MSDP peer IP address. |
route-policy WORD<1-64> |
Specifies the route policy name for an inbound or outbound filter. |
