Configure a redistribute entry to announce certain routes into the RIP domain, including static routes, direct routes, RIP, Open Shortest Path First (OSPF), IS-IS, or Border Gateway Protocol (BGP). Optionally, use a route policy to control the redistribution of routes.
Enable RIP globally.
Configure a route policy.
Create the redistribution instance, apply a route policy, enable the redistribution, and apply the redistribution.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#router rip Switch:1(config-rip)#redistribute rip Switch:1(config-rip)#redistribute rip route-map test1 Switch:1(config-rip)#redistribute rip enable Switch:1(config-rip)#exit Switch:1(config)#ip rip apply redistribute rip
Variable definitions
The following table defines parameters for the redistribute command.
Variable |
Value |
metric <0-65535> |
Configures the metric to apply to redistributed routes. |
route-map WORD<0-64> |
Configures the route policy to apply to redistributed routes. |
[vrf-src WORD<0-16>] |
Specifies the optional source VRF instance. You can use this variable with the other command variables. |
WORD<0–32> |
Specifies the type of routes to redistribute (the protocol source). Valid options are bgp, isis, direct, rip, ospf, or static. |
The following table defines parameters for the show ip rip redistribute command.
Variable |
Value |
vrf WORD<1-16> |
Specifies the VRF instance. |
vrfids WORD<1-512> |
Specifies a range of VRF IDs. |
The following table defines parameters for the ip rip apply redistribute command.
Variable |
Value |
vrf WORD<1-16> |
vrf-src WORD<0-16> |
Specifies the source VRF instance. You do not need to configure this parameter for redistribution within the same VRF. |
<bgp|direct|isis|ospf|rip|static> |
