Configure the STP mode to configure the spanning tree mode on the device.
Configure the STP mode:
Switch:1(config)# boot config
flags spanning-tree-mode mstp
Warning: Please save the configuration and reboot the switch
for this to take effect.
Warning: Please carefully save your configuration files before
starting configuring the switch in RSTP or MSTP mode.
Variable definitions
Use the data in the following table to use the boot config flags spanning-tree-mode command.
Variable |
Value |
rstp|mstp |
Specifies the Spanning Tree modes: Rapid Spanning Tree Protocol (RSTP) or Multiple Spanning Tree Protocol (MSTP). |
