Modify an existing TACACS+ configuration to customize the server.
In the
navigation pane, expand .
- Click TACACS+.
- Click TACACS+ Servers tab.
- Double-click in the
fields that you want to modify.
In some of the fields, the text becomes bold, which indicates that
you can edit them. In other fields, a list appears.
- In the fields that
you can edit, type the desired values.
- In the fields with
lists, select the desired option.
- Click Apply.
