Install a New Software Build
Use the following procedure to install a new software build for the switch.
For full software upgrade instructions, see Image Upgrade.
  1. Enter Privileged EXEC mode:
    enable
  2. Extract the release distribution files to the /intflash/release/ directory:
    software add WORD<1-99>
  3. Install the image:
    software activate WORD<1-99>
  4. Restart the switch:
    reset
Extract the release distribution files to the /intflash/release/ directory, extract the module files to the /intflash/release directory, and install the image.
Switch:1>enable
Switch:1#software add VSPX.X.X.X.X.tgz
Switch:1#software activate VSPX.X.X.X.X
Switch:1#reset
