This procedure does not apply to VSP 8600 Series and XA1400 Series.
The switch applies the Auto-sense voice configuration on specific port(s), after it discovers IP phones on the port through LLDP packets.
If you boot the switch with a configuration file, and not through Zero Touch Fabric Configuration, you must manually enable Auto-sense on specific port(s).
Perform this procedure to configure Auto-sense voice information for IP phones.
A global Auto-sense voice configuration does not require Auto-sense LLDP authentication.
Configure VLAN tagging as untagged:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#auto-sense voice i-sid 1234 untagged
The following table defines parameters for the auto-sense voice command.
Variable |
Value |
i-sid<1-16777215> |
Specifies the service instance identifier (I-SID). |
c-vid<c-vid> |
Specifies the customer VLAN ID. Different hardware platforms support different customer VLAN ID ranges. Use the CLI Help to see the available range for the switch. |
untagged |
Specifies the VLAN tagging type as untagged. Note:
The phone receives VLAN ID as 0 and the tagging is configured as "untagged". |
