This procedure does not apply to VSP 8600 Series and XA1400 Series.
Perform this procedure to display the Auto-sense configuration on the switch.
show auto-sense [access-differv] [data] [eapol] [fa] [isis] [onboarding] [qos] [voice]
show interfaces gigabitEthernet auto-sense [{slot/port[/sub-port][-slot/port[/sub-port]][,...]}]
Display the Auto-sense configuration related to voice:
Switch:1>show auto-sense voice
AUTO-SENSE VOICE Config
I-SID C-VID DSCP PRIORITY
2000 2000 46 6
1 out of 1 Total Num of AUTO-SENSE entries displayed
Display the Auto-sense status and state on a range of ports:
Switch:1>#show interfaces gigabitethernet auto-sense 1/1-1/5
Port Auto-sense
PORT AUTO-SENSE AUTO-SENSE
NUM STATUS STATE
1/1 Enable UNI-ONBOARDING
1/2 Disable OFF
1/3 Disable OFF
1/4 Disable OFF
1/5 Disable OFF
