In SPBM, B-MAC addresses are carried within the IS-IS link-state database. To do this, SPBM supports an IS-IS TLV that advertises the I-SID and B-MAC information across the network. Each node has a System ID, which also serves as Backbone MAC address (B-MAC) of the switch. These Backbone MAC addresses are populated into the SPBM VLAN Forwarding Information Base (FIB).
When the network topology is discovered and stored in the IS-IS link-state database, each node calculates shortest path trees for each source node, so that a unicast path now exists from every node to every other node. With this information, each node populates unicast information received from SPBM into the FIB for forwarding purposes.
The multicast FIB is not produced until virtual services are configured and learned.
Switch#show isis spbm multicast-fib
SPBM MULTICAST FIB ENTRY INFO
MCAST DA ISID BVLAN SYSID HOST-NAME OUTGOING-INTERFACES INCOMING
INTERFACE
03:00:07:e4:e2:02 15000066 1001 0077.0077.0077 Switch-25 1/33 MLT-2
03:00:08:e4:e2:02 15000066 1001 0088.0088.0088 Switch-33 1/50,1/33 40.40.40.40
03:00:41:00:04:4d 1101 4058 00bb.0000.4100 Switch-1(*) 1/3,1/49,0.0.0.0 Tunnel_to_HQ
03:00:41:00:04:4f 1103 4058 00bb.0000.4100 Switch-1(*) 1/3,1/49,0.0.0.0 cpp
Total number of SPBM MULTICAST FIB entries 4
The following table defines parameters for the show isis spbm multicast-fib command.
Variable |
Value |
vlan <1-4059> |
Displays the FIB for the specified SPBM VLAN. |
i-sid <1–16777215> |
Displays the FIB for the specified I-SID. |
nick-name <x.xx.xx> |
Displays the FIB for the specified nickname. |
summary |
Displays a summary of the FIB. |
Job Aid
The following section describes the fields in the output for the SPBM multicast FIB command.
The following table describes the fields in the output for the show isis spbm multicast-fib command.
Parameter |
Description |
MCAST DA |
Indicates the multicast destination MAC address of the multicast FIB entry. |
ISID |
Indicates the I-SID of the multicast FIB entry. |
BVLAN |
Indicates the B-VLAN of the multicast FIB entry. |
SYSID |
Indicates the system identifier of the multicast FIB entry. |
HOST-NAME |
Indicates the host name of the multicast FIB entry. |
OUTGOING INTERFACE |
Indicates the outgoing port of the multicast FIB entry. |
INCOMING INTERFACE |
