Use this procedure to enable Application Telemetry and configure the device used as either an sFlow Collector or an Application Telemetry Analytics Engine. This device is where the agent sends sFlow datagrams and Application Telemetry packets for analysis.
sFlow supports up to two collectors for each interface slot in the chassis. However, Application Telemetry supports Collector 1 only.
![Note](images/note.png)
You can configure two Collectors, but Application Telemetry uses Collector 1 only. You must configure Collector 1 before you enable Application Telemetry.
Before you change or remove Collector 1, you must disable Application Telemetry.
By default, Application Telemetry is globally disabled.
You must configure the sFlow agent IP address.
You must enable sFlow before you can enable Application Telemetry.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#sflow collector 1 address 192.0.2.26 owner sflow1 port 6343 timeout 497 Switch:1(config)#show sflow collector 1 ========================================================================================== sFlow Collector Configuration Info ========================================================================================== Id Owner Collector-IP Port Timeout(secs) Reachable via ------------------------------------------------------------------------------------------ 1 sflow1 192.0.2.26 6343 497 192.0.2.15 ------------------------------------------------------------------------------------------ All 1 out of 1 Total Num of sflow collector entries displayed Switch:1(config)#app-telemetry enable Switch:1(config)#show app-telemetry status Application Telemetry is enabled Collector is reachable via 192.0.2.26
Use the data in the following table to use the sflow collector command.
Variable |
Value |
<1–2> |
Specifies the ID of the collector where you want to send packets for analysis. Application Telemetry uses Collector 1 only. |
owner WORD<1–20> |
Specifies the name of the collector. |
Collector-IP {A.B.C.D.} |
Specifies the IP address of the collector. |
port <1–65535> |
Specifies the destination port. The default port is 6343. Note:
Application Telemetry does not use this parameter. |
timeout <1–65535> |
Specifies the time remaining (in seconds) before the collector is released. The default timeout is 0, which means the timeout is not used and the switch sends data forever. Note:
vrf WORD<1–16> |
Specifies the name of the VRF used to reach the collector. Note:
This parameter is not supported on all hardware platforms. |
