Display information about current IPv6 aggregate addresses.
Use BGP 4 byte AS numbers to ensure the continuity of loop-free inter-domain routing information between ASs and to control the flow of BGP updates as 2 byte AS numbers will deplete soon.
The following table defines parameters for the show bgp ipv6 aggregates command.
Variable |
Value |
WORD <1–256> |
Specifies the IPv6 prefix and the prefix length (the length can be 0 to 128). |
vrf WORD <1-16> |
Specifies a VRF instance by name (the string length ranges from 1–16 characters). |
vrfids <0–255> |
Specifies a range of VRFs by ID number (the ID ranges from 0–255). |
