This section shows examples of IPv6 DHCP snooping and ND inspection configuration.
Enable DHCPv6 Guard, ND inspection, and First Hop Security.
ipv6 fhs dhcp-guard enable
ipv6 fhs nd-inspection enable
ipv6 fhs enable
Create VLAN 1000 and add port members.
vlan create 1000 type port-mstprstp 0
vlan members add 1000 1/1-1/10
Enable DHCPv6 snooping and ND inspection on VLAN 1000.
interface vlan 1000
ipv6 fhs snooping dhcp enable
exit
Add static SBT entry.
ipv6 fhs snooping static-binding ipv6-address 2001:DB8:0:0:0001:02ff:fe03:0405 vlan 1000 mac-address 00:01:02:03:04:05 port 1/5
Set the DHCPv6 Guard device-role on port 1/1 of the device on which DHCPv6 Guard is configured.
interface gigabitEthernet 1/1
ipv6 fhs dhcp-guard device-role server
exit
Enable ND inspection on ports 1/2 through 1/10.
interface gigabitEthernet 1/2-1/10
exit
View the status.
show ipv6 fhs port-policy
show ipv6 fhs status
show ipv6 fhs status vlan
show ipv6 fhs snooping binding
