This procedure does not apply to VSP 4450 Series, VSP 8600 Series, or XA1400 Series.
- Enable EAP globally or on the port.
Configure an I-SID offset value and enable I-SID offset globally on the switch:
Switch:1> enable Switch:1#config terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#eapol auto-isid-offset 1000 Switch:1(config)#eapol enable
View the current device configuration:
Not all fields are supported on all hardware platforms.
Switch:#enable
Switch:1#show eapol system
Eapol System
eap : disabled
Eapol Version : 3
non-eap-pwd-fmt : mac-addr
non-eap-pwd-fmt key : ******
non-eap-pwd-fmt padding : disabled
auto-isid-offset status : disabled
auto-isid-offset value : 1000
The following table defines parameters for the eapol auto-isid-offset command.
Variable |
Value |
<0-15995903> Note:
Exception: Not supported on VSP 4450 Series, VSP 8600 Series, or XA1400 Series. |
Specifies the auto isid offset value. The default is 15995903. |
enable
Note:
Enables auto isid offset. The default is disabled. |
