Use this procedure to view global LLDP information, to know which LLDP settings and parameters are configured.
View global LLDP information:
Switch:1#show lldp
802.1ab Configuration:
TxInterval: 30
TxHoldMultiplier: 4
ReinitDelay: 1
TxDelay: 1
NotificationInterval: 5
View the LLDP local system data on the switch:
Switch:1#show lldp local-sys-data
LLDP Local System Data
ChassisId: MAC Address b0:ad:aa:4c:54:00
SysName : LLDP agent
SysDescr : VSP-4450GSX-PWR+ (6.0.1.0) BoxType: VSP-4450
SysCap : Br / Br
Capabilities Legend: (Supported/Enabled)
B= Bridge, D= DOCSIS, O= Other, R= Repeater,
S= Station, T= Telephone, W= WLAN, r= Router
View the LLDP neighbor information. You can also view this on a specific port.
Switch:1#show lldp neighbor
LLDP Neighbor
Port: 1/28 Index : 1 Time: 0 day(s), 01:16:25
Protocol : LLDP
ChassisId: MAC Address a4:25:1b:52:54:00
PortId : MAC Address a4:25:1b:52:54:1b
SysName : BEB
SysCap : Br / Br
PortDescr: VSP8404 - Gbic1000BaseT Port 1/28
SysDescr : VSP8404 (4.5.0.0)
Address : 192.0.2.47
Total Neighbors : 1
View the LLDP neighbor summary of all ports on the switch. You can also view this on a specific port.
The EDM tab ( displays only IPv4 addresses. Use CLI to see both IPv4 and IPv6.
Switch:1#show lldp neighbor summary
LLDP Neighbor Summary
LOCAL IP/IPv6 CHASSIS REMOTE
PORT PROT ADDR ID PORT SYSNAME SYSDESCR
1/4 LLDP 0.0.0.0 f8:15:47:e1:dd:00 f8:15:47:e1:dd:06 VSP-4450GSX-~ VSP-4450GSX-PWR+ (6.0.1.0)
1/12 LLDP 192.0.2.77 a4:25:1b:53:6c:00 a4:25:1b:53:6c:28 VSP-7254XTQ VSP-7254XTQ (6.0.0.0)
1/13 LLDP 192.0.2.34 00:14:0d:e3:40:00 00:14:0d:e3:40:c1 ERS-8606 ERS-8606 (7.2.10.1)
1/14 LLDP 192.0.2.78 a4:25:1b:52:34:00 a4:25:1b:52:34:28 VSP-7254XSQ VSP-7254XSQ (6.0.0.0)
1/24 LLDP 192.0.2.94 00:13:65:a3:8c:00 00:13:65:a3:8c:18 Ethernet Routing Switch 5520-~
1/25 CDP 192.0.2.89 -- FastEthernet2/0/5 cisco3750.Tr~ cisco WS-C3750-48P running on~
1/27 CDP 0.0.0.0 -- FastEthernet3/0/6 Switch cisco WS-C3750-48TS running o~
1/48 LLDP 192.0.2.76 b0:ad:aa:4e:dc:00 b0:ad:aa:4e:dc:68 VSP-8404 VSP-8404 (6.0.0.0)
Total Neighbors : 8
View the LLDP administrative status of all ports on the switch. You can also view this on a specific port.
Switch:1#show lldp port
LLDP Admin Port Status
Port AdminStatus ConfigNotificationEnable CdpAdminState
1/1 txAndRx disabled disabled
1/2 txAndRx disabled disabled
1/3 txAndRx disabled disabled
1/4 txAndRx disabled disabled
View the LLDP reception statistics. You can also view this on a specific port.
Switch:1#show lldp rx-stats
LLDP Rx-Stats
Port Frames Frames Frames TLVs TLVs AgeOuts
Num Discarded Errors Total Discarded Unsupported
(Non FA) (Non FA)
1/1 0 0 0 0 0 0
1/2 0 0 0 0 0 0
1/3 0 0 0 0 0 0
1/4 0 0 0 0 0 0
View the LLDP statistics:
Switch:1#show lldp stats
LLDP Stats
Inserts Deletes Drops Ageouts
4 0 0 0
View the LLDP transmission statistics:
Switch:1#show lldp tx-stats
LLDP Tx-Stats
PORT NUM FRAMES
1/1 95
1/2 95
1/3 95
1/4 95
1/5 95
Display LLDP-MED local system data:
Switch:1#show lldp local-sys-data med
ChassisId: MAC Address d4:78:56:f1:65:00
SysName : VSP-4450GSX-PWR+
SysDescr : VSP-4450GSX-PWR+ (w.x.y.z)
SysCap : Br / Br
MED Capabilities: CNLSI
MED Device Type: Network Connectivity Device
MED Power Device Type: PSE Device
HWRev: 03 FWRev: VU-Boot 2012.04-00034-g57194a8
SWRev: v5.7.3.005 SerialNumber: 16JP1160E51D
ManufName: Extreme Networks. ModelName: VSP-4450GSX-PWR+
Asset ID: 16JP1160E51D
Port: 1/1
MED Enabled Capabilities: CNLI
MED Network Policy:
Application Type: Voice
VLAN ID: 412
L2 Priority: 3
DSCP Value: 57
Tagging: Tagged Vlan
Policy defined
Application Type: Voice-Signaling
VLAN ID: 7
L2 Priority: 6
DSCP Value: 24
Policy defined
MED Location - Coordinate-based LCI:
Latitude: +12.3 (degrees) North
Longitude: +42 (degrees) East
Altitude: +45 (meters)
Datum: World Geodesic System (WGS84)
MED Location - Civic Address LCI:
Country code: RO
Country: Romania
City: Bucuresti
Block: 12
Street: Calea Floreasca
Floor: 3
MED Location - Emergency Call Service ELIN:
ECS ELIN: 121416182022
MED Extended Power via MDI:
Power Value: 16.0 Watt
Power Type: PSE
Power Source: Primary
Power Priority: Low
MED Capabilities Legend: (Supported/Enabled)
C= Capabilities, N= Network Policy; L= Location Identification;
I= Inventory; S= Extended Power via MDI - PSE; D= Extended Power via MDI - PD.
The following table defines parameters for the show lldp command.
Variable |
Value |
local-sys-data |
Displays the LLDP local system data. |
neighbor [summary] [port {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}] |
Displays the LLDP neighbor system information. You can also view this on a specific port. Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
port [{slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}] |
Displays the LLDP administrative status of a port or all ports on the switch. Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
rx-stats [port {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}] |
Displays the LLDP reception statistics on all ports on the switch, or on a specific port. Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
stats |
Displays the LLDP statistics. |
tx-stats [port {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}] |
Displays the LLDP transmission statistics on all ports on the switch or on a specific port. Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
