Creating Multiple Users
DEMO FEATURE - Multiple CLI Users Per Role is a demonstration feature on some products. Demonstration features are provided for testing purposes. Demonstration features are for lab use only and are not for use in a production environment. For more information on feature support, see VOSS Feature Support Matrix.
You can create up to seven new CLI user roles on the switch, in addition to the three default CLI user roles. The username must be unique. If you enable the hsecure flag, password complexity rules apply to all users.
You must use an EDM account with read-write-all privileges to create new CLI users.
Use this task to create multiple CLI users on the switch using EDM.
- Click General.
- Click the Multiple Users tab.
- Click Insert.
- Type the ID.
- Type a unique user name.
- Type a password.
- Select the access level.
- Select Enable to activate the user account.
- Click Insert.
Multiple Users field descriptions
Use the data in the following table to the use the Multiple Users tab.
Name |
Description |
Id |
Specifies the unique ID. |
Name |
Specifies the username. |
Password |
Specifies the password. |
Level |
Specifies the user access level.
Enable |
Enables the user access on the switch. |
Type |
Specifies the user type. |
