Use the following procedure to display IPsec policies.
Display IPsec policy information:
Switch:1>show ipsec policy all
IPSEC Policy Table
PolicyName : ospf1
LocalAddress: 0::0
RemoteAddress: 0::0
Protocol: ospfv3
src-port: 0
dest-port: 0
Action: Permit
Admin: Enable
Switch:1>show ipsec policy interface ospf1
IPsec Policy Interface Table
POLICY NAME InterfaceIndex Policy State Direction
ospf1 2/3 Enable both
Switch:1>show ipsec policy name ospf1
IPSEC Policy Table
PolicyName : ospf1
LocalAddress: 0::0
RemoteAddress: 0::0
Protocol: ospfv3
src-port: 0
dest-port: 0
Action: Permit
Admin: Enable
The following table defines parameters for the show ipsec policy command.
Variable |
Value |
all |
Displays all of the IPsec policies on the switch. |
interface WORD<1–32> |
Displays a specific IPsec policy based on the policy name on the interface. |
name WORD<1–32> |
Displays the IPsec policy based on the name of the policy. |
Job aid
The following table describes the fields in the output for the show ipsec policy all and show ipsec policy name commands.
Parameter |
Description |
PolicyName |
Specifies the IPsec policy name. |
LocalAddress |
Specifies the local address. The default is 0::0. |
RemoteAddress |
Specifies the remote address. The default is 0::0. |
Protocol |
Specifies the protocol. |
src-port |
Specifies the source port. |
dest-port |
Specifies the destination port. |
Action |
Specifies the action as either: permit or drop. |
Admin |
Specifies whether the policy is enabled. |
The following table describes the fields in the output for the show ipsec policy interface command.
Parameter |
Description |
POLICY NAME |
InterfaceIndex |
Specifies the interface. |
Policy State |
