Display information about BGP+ network configurations.
The following table defines parameters for the show bgp ipv6 networks command.
Variable |
Value |
<WORD 1–256> |
Specifies the IPv6 prefix and the prefix length (must be an integer value between 0 and 128). |
vrf |
Specifies a VRF instance by name (the string length ranges from 1–16 characters). |
vrfids |
Specifies a range of VRFs by ID number (the ID ranges from 0–255). |
