View port policer statistics to manage network performance.
This tab does not appear for all hardware models.
- Click Port.
- Click the Policer tab.
Policer Field Descriptions
Use the data in the following table to use the Policer tab.
Name |
Description |
TotalPkts |
Shows the total number of packets received on the port. |
TotalBytes |
Shows the total number of bytes received on the port. |
YellowBytes |
Shows the total number of bytes received on the port that were above the committed rate but below the peak rate. |
RedBytes |
Shows the total number of bytes received on the port that were above the peak rate. |
