Use this procedure to graphically view the LLDP reception statistics.
LLDP operates at the port interface level. Enabling FA on a port automatically enables LLDP transmission and reception on that port. It also enables traffic tagging and disables spanning tree on that port.
Enabling FA on an MLT enables LLDP transmission and reception on all ports in that MLT.
When a port is removed from an MLT, LLDP transmission on that port stops and spanning tree is enabled. Any I-SID-to-VLAN mappings on that port are removed, if not already learned on any other port in the MLT. This also causes the Switched UNI I-SID to be deleted from the MLT. However, if the mappings are learned on another port on the MLT, the Switched UNI I-SID continues to exist for that MLT.
For ports in an LACP MLT, when FA is enabled, tagging is enabled on all ports in the LACP MLT. The consistency check for FA is based on key membership. If all ports with the same key do not support FA, FA is not successfully enabled on those ports.
If a slot is removed from the switch chassis, the statistics are not displayed on the slot ports. When the slot is inserted back again, the statistics counters are reset.
- Click the RX Stats tab.
- To view the reception
statistics graphically for a port:
- To clear the existing counters, and fix a reference point in time to restart the counters, click Clear Counters.
- To export the statistical data to a file, click Export.
- To configure a poll interval, select an appropriate value from the Poll Interval drop-down list.
RX Stats Field Descriptions
Use the data in the following table to use the RX Stats tab.
Name |
Description |
FramesDiscardedTotal |
Specifies the number of LLDP frames received on the port, but discarded, for any reason. This counter provides an indication of possible LLDP header formatting problems in the sending system, or LLDP PDU validation problems in the receiving system. |
FramesErrors |
Specifies the number of invalid LLDP frames received on the port. |
FramesTotal |
Specifies the total number of LLDP frames received on the port. |
TLVsDiscardedTotal |
Specifies the number of LLDP TLVs discarded on the port, for any reason. |
TLVsUnrecognizedTotal |
Specifies the number of LLDP TLVs on the port, that are unrecognized on that port. An unrecognized TLV is referred to as the TLV whose type value is in the range of reserved TLV types (000 1001–111 1110). An unrecognized TLV could be, for example, a basic management TLV from a later LLDP version. |
