You must perform deletion steps in the correct order.
If you attempt to delete the Management Instance VLAN before you delete the platform VLAN, the following error message displays:
Error: On a DVR leaf, the vlan must be deleted before the mgmt vlan instanceIf you attempt to delete the platform VLAN before disabling the Management Instance VLAN, the following error message displays:
Error: Cannot delete vlan if mgmt vlan interface is enabledAbout this task
The following table defines parameters for the no vlan command.
| Variable | Value |
<2-4059> |
Specifies the ID of the platform VLAN to be deleted. |
