Ensure that the switch is running.
Note the IP address of the switch.
Ensure that you use a supported browser version.
Ensure that you enable the web server using CLI.
Perform this procedure to connect to EDM to configure and maintain your network through a graphical user interface.
By default the Web server is configured with the secure-only option, which requires you to use HTTPS to access EDM. To access EDM using HTTP, you must disable the secure-only option.
The default is admin.
The default is password.
