Enable an MKA on a Port
Ensure that you apply an MKA profile to the port and associate the port with a Connectivity Association (CA) before you enable MKA on the port.
Use the following procedure to enable a MACsec Key Agreement (MKA) profile on a port.
- In the Device Physical View, select the port to which you want to apply an MKA profile.
- Select General.
- Select the MACsec MKA tab.
- For MACsecMKAProfileName, select the name of the MKA profile you want to apply.
- Select MKA Enable to enable MKA on the port.
- Select Apply.
MACsec MKA Field Descriptions
Use the data in the following table to use the MACsec MKA tab.
| Name | Description |
MACsecMKAProfileName |
Specifies the MKA profile name. |
MKA Enable |
Enables the MKA profile on the port. The default is disabled. |
