Use the following command to display uPnP Filtering information on an IGMP-enabled interface.
View the default uPnP Filtering information on an IGMP-enabled interface:
Switch:(config)#show ip igmp interface vlan 2
Vlan Ip Igmp
VLAN QUERY QUERY ROBUST VERSION LAST PROXY SNOOP SSM UPnP FAST FAST
ID INTVL MAX MEMB SNOOP ENABLE SNOOP FILTER LEAVE LEAVE
RESP QUERY ENABLE ENABLE ENABLE ENABLE PORTS
2 125 100 2 2 10 false false false false false
VLAN SNOOP SNOOP DYNAMIC COMPATIBILITY EXPLICIT UPnP
ID QUERIER QUERIER DOWNGRADE MODE HOSTS FILTER
ENABLE ADDRESS VERSION TRACKING ADDRESS
2 false 0.0.0.0 enable disable disable 239.255.255.250/32
View uPnP Filtering information on an IGMP-enabled interface when uPnP Filtering is enabled and a non-default multicast group address is configured:
Switch:1(config)#show ip igmp interface vlan 2
Vlan Ip Igmp
2 125 100 2 2 10 false false false true false
2 false 0.0.0.0 enable disable disable 233.252.0.0/24
Variable definitions
The following table defines parameters for the show ip igmp interface command.
Variable |
Value |
gigabitethernet {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
vlan <1-4059> |
Specifies the VLAN. |
vrf WORD<1–16> |
Specifies the VRF by name. |
vrfids WORD<0–512> |
Specifies the VRF by VRF ID. |
