Reset the platform to reload system parameters from the most recently saved configuration file.
Reset the switch:
Switch:1>enable Switch:1#reset Are you sure you want to reset the switch? (y/n) y
Variable definitions
Use the data in the following table to use the reset command.
Variable |
Value |
-y |
Suppresses the confirmation message before the switch resets. If you omit this parameter, you must confirm the action before the system resets. |
