While the EDM GUI is bundled with the switch software, the associated EDM help files are not. To access the help files from the EDM GUI, you must install the EDM help files on a TFTP or FTP server in your network.
Use the following procedure to install the EDM help files on a TFTP or FTP server, and configure EDM to use the help files
If you use an FTP server to store the help files, ensure that you configure the switch with the host user name and password.
Tip
You can name the directory anything that will help you remember its purpose.
