IPsec compression reduces the size of the IP datagram to improve the communication performance between hosts connected behind XA1400 Series Backbone Edge Bridges (BEB).
Tip
As a best practice, use IPsec compression only for Fabric Extend tunnels where latency is greater than 70ms.
The following list identifies how you can implement IPsec compression:
You can configure IPsec compression for each logical-interface.
You can configure multiple IPsec Fabric Extend adjacencies with or without compression at the same time.
You must enable IPsec compression on both BEBs to use IPSEC compression for an FE adjacency.
You can change the IPsec compression configuration for a logical interface only if IPsec is disabled on the logical interface.
For configuration information, see the following tasks:
Configure Fabric Extend Over IPsec (using CLI)
Configure Fabric Extend Logical Interfaces (using EDM)
