The following section shows the steps required to configure TACACS+ on Identity Engines
      Ignition Server, Release 8.0. Use the preceding information to configure the switch.
    A TACACS+ server responds to and audits network access requests. In an installation, the
      Identity Engines Ignition Server is the TACACS+ server.
    The example displays how to do the following:
          Enable TACACS+
          Configure a user
          Create a command set
          Configure the authentication protocol policy
          Create the authorization policy
          Configure TACACS+ authenticators
For more information on the Ignition Server, see Identity Engines Ignition Server
        Administration.
            Configure the Ignition Server appliance and set up its network settings. For more
              information, see Identity Engines
                Ignition Server Getting Started.
            Install the Ignition Dashboard on your Windows OS.
            Configure each authenticator (switch) to recognize the Ignition Server appliance as
              its TACACS+ server.
            Configure your switch to send packets to the Ignition Server appliance with the
              appropriate IP address and port.
            Ensure licenses are up-to-date.
        If the Ignition Server Dashboard is not
          connected to your Ignition Server, select Administration: Login to
          connect.
            The default login credentials for
                User Name and
                Password are
                admin/admin. change the default values.
             In the Connect to field enter
              the IP address of the Ignition Server for TACACS+. In this example, the IP address for
              the TACACS+ server is 192.0.2.8.
        Enable TACACS+.
            In the Ignition Server Dashboard,
              select Site
              0.
            In the Sites window, select the
                Services
              tab.
            Under the Services tab, select
                the TACACS+
              tab.
            Click the Edit button in the
              TACACS+ tab.
            In the Edit TACACS+ Configuration dialog
              box, select the Protocol is
                enabled box.
            In the Bound Interface field,
              select Admin Port.
            In the Port field, enter
                49.
            Select Accept Requests from Any
                Authenticator.
              Select this option if you want to create a global TACACS+ authenticator that sets
                policy for all authenticators that do not match a specific TACACS+-enabled
                authentication in your Ignition Server configuration.
            In the Access Policy field,
              select default-tacacs-admin.
              Use this configuration in the case of a global TACACS+ authenticator. Choose your
                global TACACS+ policy that you want applied if the device finds no better matching
                authenticator.
            In TACACS+ Shared Secret
              field, enter the secret that the switch and TACACS+ Ignition Server share. In this
              example, the shared secret is secret.
            Click OK.
        Configure a user recognized by the
          TACACS + server.
              expand the Configuration tree: .
            Click New.
            Fill in the appropriate
              fields.
              As an example: User Name: jsmith First Name: John Last Name: Smith Password: test Confirm password: test
        If your TACACS+ policy uses per-command
          authorization, create a command set.
            Click Define Command
              Sets.
            Click New.
            In the New Device Command Set
              window, type a Name and Description for the command set; for instance, level5.
               In this window you build your command set by adding commands to the list. You can
                build the command list manually or you can import a list. For more information on
                importing a command list, see Identity Engines Ignition Server Administration.
            To manually add the commands, click
                Add in the
              New/Edit Device Command Set window.
            Click the Simple Command Using Keywords and
                Arguments box.
            In the Command field, type the
              command, and optionally its arguments.
            To allow the command to be used with
              any argument, select the Allow box.
            To allow only the specific command
              and arguments you have types, tick the Deny box.
            Click OK to add the command to
              the list.
            Continue to add the commands that
              you want.
          privilege-level authorization, create the TACACS+ access policy to allow the TACACS+
          Ignition Server to communicate with the switch.
            Select default-tacacs-admin.
            Click on the Authorization Policy tab
              and select the name of the policy you want to edit.
            Click Edit and the Edit Authorization Policy
              window appears.
            In the Rules section, select the
              rule you want to edit. In this case select level5, to which you have already added
              commands.
              The Rules
                list at the left lets you browse and sort the rules in your policy. Use the up and
                down arrow buttons at the right to set the rule sequence, and click a rule name in
                the list to edit that rule. The Selected Rule Details section lets you edit the rule
                you have selected.
            In the Selected Rule Details
              section, under Rule
                Name, for this example, it reads level5.
            Select  Rule Enabled.
            With level5 selected in the Rules
              list, go to the buttons to the right of the Constraint list and click
                New.
            In the Action section, select
                Allow.
            Select the Command Sets tab, in the
              Action section. Allow Commands in Set should read level-5, in this example, and under
              All Command Sets all the commands that are accessible under level5 should be
              listed.
            Click OK.
              For this example to function properly, the summary window must display: IF User: user-id = level5 THEN Allow Permit commands in Command Set: level-5
        Configure the Ignition Server to connect
          to authenticators, which is the switch:
              expand  and the Authenticator Summary window appears.
            Click New, and the
              Authenticator Details window appears.
             For this example, type Switch1 under name.
            To the right select Enable Authenticator.
            Type the IP address for the switch,
              which is the authenticator. Use the primary CPU address or the management virtual
              address.
            In the Vendor field, select
                Nortel.
            In the Device template field,
              select ers-switches-nortel.
            Select the TACACS+ Settings
              tab.
            Select Enable TACACS+
              Access.
            In the TACACS+ Shared Secret
              field, type the key value you entered into the switch. In this example, the key is the
              word secret.
              To connect using TACACS+, you must use the shared secret for each device. In your
                switch documentation, the shared secret can also be referred to as a specific key
                string or an encryption string.
            Under Access Policy, select
                default-tacacs-user.
            Click  OK.
