Display the authenticator statistics to manage network performance.
Use the clear-stats command to clear EAP or NEAP statistics.
Slot and port information can differ depending on hardware platform.
Switch:1#show eapol auth-stats interface
Eap Authenticator Statistics
PORT EAP AUTH-EAP START LOGOFF INVALID LENGTH LAST-RX LAST-RX
RCVD TX RCVD RCVD FRAMES ERROR VER SRC
1/1 716 1074 0 0 0 0 1 18:a9:05:b1:04:ce
1/2 0 0 0 0 0 0 0 00:00:00:00:00:00
1/3 0 0 0 0 0 0 0 00:00:00:00:00:00
1/4 0 5 0 0 0 0 0 00:00:00:00:00:00
1/5 0 0 0 0 0 0 0 00:00:00:00:00:00
1/6 0 0 0 0 0 0 0 00:00:00:00:00:00
1/7 0 0 0 0 0 0 0 00:00:00:00:00:00
1/8 0 0 0 0 0 0 0 00:00:00:00:00:00
1/9 0 0 0 0 0 0 0 00:00:00:00:00:00
1/10 0 0 0 0 0 0 0 00:00:00:00:00:00
--More-- (q = quit)
Use the data in the following table to use the show eapol auth-stats interface command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
Job Aid
The following table describes the output for the show eapol auth-stats interface command.
Parameter |
Description |
PORT |
Displays the port number in use. |
EAP RCVD |
Displays the number of EAPoL-EAP frames received by this Authenticator. |
AUTH-EAP TX |
Displays the number of EAPoL-EAP frames transmitted by the Authenticator. |
START RCVD |
Displays the number of EAPoL start frames received by this Authenticator. |
LOGOFF RCVD |
Displays the number of EAPoL logoff frames received by this Authenticator. |
INVALID FRAMES |
Displays the number of EAPoL frames received by this Authenticator in which the frame type is not recognized. |
LENGTH ERROR |
Displays the number of EAPoL frames received by this Authenticator in which the Packet Body Length field is invalid. |
LAST-RX VER |
Displays the last received version of the EAPoL frame by this Authenticator. |
LAST-RX SRC |
Displays the source MAC address of the last received EAPoL frame by this Authenticator. |
