Associating VLANs with an ACL
Associate VLANs with an ACL to apply filters to VLAN traffic.
A VLAN can be part of two different ACLs of different types: IPv6 and non-IPv6.
The ACL exists.
Variable definitions
Use the data in the following table to use the filter acl vlan command.
Variable |
Value |
<acl-id> |
Specifies the ACL ID. Use the CLI Help to see the available range for the switch. |
<1-4059> |
