Use the show ha-state command to view detailed information on High Availability (HA) state of the system.
The syntax for this command is as follows.
show ha-state
The following example shows sample command output.
Switch:1(config)#show ha-state Current CPU State : Initialization state.
Use the show sys-info command to view the slots of the master CPU and the standby CPU. You can also check whether the standby CPU is running in hot standby mode or warm standby mode.
