Table 1. MACsec product support
Feature
Product
Release introduced
For configuration details, see VOSS User Guide.
MACsec 2AN mode
Note:
VOSS 5.0 officially removed the replay protection commands. Do not use replay protection in earlier releases.
5520 Series
Not Supported
VSP 4450 Series
VSP 4000 4.0
VSP 4900 Series
Not Supported
VSP 7200 Series
VOSS 4.2.1
VSP 7254XTQ only
VSP 7400 Series
Not Supported
VSP 8200 Series
VOSS 4.1
VSP 8400 Series
VOSS 4.2
VSP 8600 Series
Not Supported
XA1400 Series
Not Supported
MACsec 4AN mode
5520 Series
VOSS 8.2.5
  • 5520-24T and 5520-24W - all fixed ports except 1/25 and 1/26
  • 5520-12MW-36W, 5520-48SE, 5520-48T, and 5520-48W - all fixed ports except 1/49 and 1/50
  • VIMs: 5520-VIM-4XE and 5520-VIM-4YE only
VSP 4450 Series
VOSS 6.0
VSP 4900 Series
VOSS 8.1
VSP 7200 Series
VOSS 6.0
VSP 7254XTQ only
VSP 7400 Series
Not Supported
VSP 8200 Series
VOSS 6.0
VSP 8400 Series
VOSS 6.0
VSP 8600 Series
VSP 8600 4.5
XA1400 Series
Not Supported
MACsec encryption cipher suites
5520 Series
VOSS 8.2.5
VSP 4450 Series
VOSS 8.1
128 bits only
VSP 4900 Series
VOSS 8.1
  • VSP4900-48P supports 128-bit on all fixed ports.
  • VSP4900-24XE supports 128-bit and 256-bit on all fixed ports.
  • VSP4900-12MXU-12XE supports 128-bit and 256-bit on the SFP+ ports.
  • VIM5-4XE and VIM5-4YE supports 128-bit and 256-bit cipher suite.
VSP 7200 Series
VOSS 8.1
128 bits only
VSP 7400 Series
Not Supported
VSP 8200 Series
VOSS 8.1
128 bits only
VSP 8400 Series
VOSS 8.1
128 bits only
VSP 8600 Series
VSP 8600 6.2
8624XS supports 128 bits only. 8606CQ supports 128 bits and 256 bits.
XA1400 Series
Not Supported
MACsec Key Agreement (MKA)
5520 Series
Not Supported
VSP 4450 Series
Not Supported
VSP 4900 Series
Not Supported
VSP 7200 Series
Not Supported
VSP 7400 Series
Not Supported
VSP 8200 Series
Not Supported
VSP 8400 Series
VOSS 8.1
VSP 8600 Series
Not Supported
XA1400 Series
Not Supported
