View ICMP statistics for ICMP configuration information.
- Click IPv6.
- Click Interfaces tab.
- Select the interface on which you want to view the ICMP statistics.
- Click ICMPstats option from the menu.
ICMP stats Field Descriptions
Use the data in the following table to use the ICMP Statistics tab.
Name |
Description |
InMsgs |
Specifies the total number of ICMP messages which the entity received. Note:
This counter includes all those counted by icmpInErrors. |
InErrors |
Specifies the number of ICMP messages which the entity received but determined as having ICMP-specific errors (bad ICMP checksums, bad length, etc.). |
InDestUnreachs |
Specifies the number of ICMP Destination Unreachable messages received by the interface. |
InAdminProhibs |
Specifies the number of ICMP destination unreachable/communication administratively prohibited messages received by the interface. |
InTimeExcds |
Specifies the number of ICMP Time Exceeded messages by the interface. |
InParmProblems |
Specifies the number of ICMP Parameter Problem messages received by the interface. |
InPktTooBigs |
Specifies the number of ICMP Packet Too Big messages received by the interface. |
InEchos |
Specifies the number of ICMP Echo (request) messages received by the interface. |
InEchoReplies |
Specifies the number of ICMP Echo Reply messages received by the interface. |
InRouterSolicits |
Specifies the number of ICMP Router Solicit messages received by the interface. |
InRouterAdvertisements |
Specifies the number of ICMP Router Advertisement messages received by the interface |
InNeighborSolicits |
Specifies the number of ICMP Neighbor Solicit messages received by the interface. |
InNeighborAdvertisements |
Specifies the number of ICMP Neighbor Advertisement messages received by the interface. |
InRedirects |
Specifies the number of ICMP Redirect messages received by the interface. |
InGroupMembQueries |
Specifies the number of ICMPv6 Group Membership Query messages received by the interface |
InGroupMembResponses |
Specifies the number of ICPv6 Group Membership Response messages received by the interface. |
InGroupMembReductions |
Specifies the number of ICMPv6 Group Membership Reduction messages received by the interface. |
OutMsgs |
Specifies the total number of ICMP messages which this interface attempted to send. Note that this counter includes all those counted by icmpOutErrors. |
OutErrors |
Specifies the number of ICMP messages which this interface did not send due to problems discovered within ICMP such as a lack of buffers. This value should not include errors discovered outside the ICMP layer such as the inability of IPv6 to route the resultant datagram. In some implementations there may be no types of error which contribute to this counter's value. |
OutDestUnreachs |
Specifies the number of ICMP Destination Unreachable messages sent by the interface. |
OutAdminProhibs |
Specifies the number of ICMP destination unreachable/communication administratively prohibited messages sent. |
OutTimeExcds |
Specifies the number of ICMP Time Exceeded messages sent by the interface. |
OutParmProblems |
Specifies the number of ICMP Parameter Problem messages sent by the interface. |
OutPktTooBigs |
Specifies the number of ICMP Packet Too Big messages sent by the interface. |
OutEchos |
Specifies the number of ICMP Echo (request) messages sent by the interface. |
OutEchoReplies |
Specifies the number of ICMP Echo Reply messages sent by the interface. |
OutRouterSolicits |
Specifies the number of ICMP Router Solicitation messages sent by the interface. |
OutRouterAdvertisements |
Specifies the number of ICMP Router Advertisement messages sent by the interface. |
OutNeighborSolicits |
Specifies the number of ICMP Neighbor Solicitation messages sent by the interface. |
OutNeighborAdvertisements |
Specifies the number of ICMP Neighbor Advertisement messages sent by the interface. |
OutRedirects |
Specifies the number of Redirect messages sent. For a host, this object will always be zero, since hosts do not send redirects. |
OutGroupMembQueries |
Specifies the number of ICMPv6 Group Membership Query messages sent. |
OutGroupMembResponses |
Specifies the number of ICMPv6 Group Membership Response messages sent. |
OutGroupMembReductions |
Specifies the number of ICMPv6 Group Membership Reduction messages sent. |
