Creating IPv6 static routes
Use static routes to manually configure routes to destination IPv6 address prefixes.
Not all parameters are available in non-default VRFs.
Enable IPv6 static routes globally:
Switch:1(config)#ipv6 route static enable
Create and enable a static route through a global nexthop:
Switch:1(config)#ipv6 route 4000::/64 cost 1 next-hop 3000::2 enable
Create and enable a static route through an outgoing interface (VLAN or brouter port):
Switch:1(config)# ipv6 route 4000::/64 cost 1 vlan 1900 enable
Create and enable a static route through a link local nexthop and an outgoing interface:
Switch:1(config)# ipv6 route 4000::/64 cost 1 next-hop fe80::1 vlan 1900 enable
In the preceding example, you must specify the outgoing interface so that the system can apply the correct context to the link-local address.
Variable definitions
Use the data in the following table to use the ipv6 route command.
Variable |
Value |
WORD <0–46> |
Specifies the IPv6 destination address and prefix. |
enable |
Enables the static route. The default is enabled. |
cost <1–65535> |
Specifies the cost or distance ratio to reach the destination for this static route. The default is 1. |
next-hop Word <0–46> |
Specifies the IPv6 address of the next hop on this route. You do not need to specify the next hop if the devices directly connect to one another. Configure the next hop if the two nodes do not share the same network prefix but reside on the same link. |
preference <1–255> |
Specifies the routing preference of the destination IPv6 address. The default is 5. |
{slot/port[/sub-port]} |
Identifies a single slot and port. If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
tunnel <1–2000> |
Specifies the tunnel ID. |
vlan <1-4059> |
