You can enable or disable routing capabilities on a VLAN or brouter port.
enable
configure terminal
interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]} or interface vlan <1–4059>
routing enable
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface gigabitethernet 1/2 Switch:1(config-if)#routing enable
