Troubleshooting BPDU Guard
The following procedures provide information to troubleshoot issues with Bridge Protocol Data Unit (BPDU) Guard.
For BPDU Guard to work on a port, the port must receive BPDU packets. Perform the following procedure to troubleshoot cases when the port does not receive packets.
Port 1/8 receives packets. The remote port is disabled and does not send BPDU packets.
The following example shows that BPDU Guard is enabled for port 1/8. The BPDU Guard administrative state for the port is enabled but the timer counter is 0.
Switch:1>enable
Switch:1#show spanning-tree bpduguard 1/8
Bpdu Guard
Port PORT PORT TIMER BPDUGUARD
NUM MLTID ADMIN_STATE OPER_STATE TIMEOUT COUNT ADMIN_STATE
1/8 Up Up 120 0 Enabled
Switch:1#show interface gigabitEthernet statistics verbose 1/8
Port Stats Interface Extended
PORT_NUM IN_UNICST OUT_UNICST IN_MULTICST OUT_MULTICST IN_BRDCST OUT_BRDCST IN_LSM OUT_LSM
1/8 201 0 160062 60943 4 72 0 0
Switch:1#show spanning-tree mstp port role 1/8
CIST Port Roles and States
Port-Index Port-Role Port-State PortSTPStatus PortOperStatus
1/8 Disabled Forwarding Disabled Disabled
Switch:1#show spanning-tree mstp port statistics 1/8
MSTP Cist Port Statistics
Port Number : 1/8
Cist Port Fwd Transitions : 0
Cist Port Rx MST BPDUs Count : 0
Cist Port Rx RST BPDUs Count : 0
Cist Port Rx Config BPDUs Count : 0
Cist Port Rx TCN BPDUs Count : 0
Cist Port Tx MST BPDUs Count : 0
Cist Port Tx RST BPDUs Count : 0
Cist Port Tx Config BPDUs Count : 0
Cist Port Tx TCN BPDUs Count : 0
Cist Port Invalid MSTP BPDUs Rx : 0
Cist Port Invalid RST BPDUs Rx : 0
Cist Port Invalid Config BPDUs Rx : 0
Cist Port Invalid TCN BPDUs Rx : 0
Cist Port Proto Migr Count : 0
Use the data in the following table to use the show spanning-tree bpduguard command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
Use the data in the following table to use the show interface gigabitEthernet statistics verbose command.
Variable |
Value |
Use the data in the following table to use the show spanning-tree command.
Variable |
Value |
{mstp|rstp} |
Specifies the spanning tree protocol. |
