Perform this procedure to load a configuration file to the Fabric IPsec Gateway Virtual Machine (VM).
Loading a configuration file to the VM.
Switch:1> enable Switch:1# virtual-service figw console Connected to domain figw Escape character is ^Y <cr> FIGW> load coupled.cfg
The following table defines the variable for load command.
| Variable | Value |
| WORD <1-255> | Specifies the configuration file name. |
