View current SLPP Guard settings.
- Click SLPP.
- Click the SLPP Guard tab.
SLPP Guard Ethernet type field descriptions
Use the data in the following table to use the SLPP Guard tab.
Name |
Description |
IfIndex |
Specifies the port on which to configure SLPP Guard. |
Enable |
Enables (true) or disables (false) SLPP Guard for the port. The default is disabled. |
Timeout |
Specifies the time period, in seconds, for which SLPP Guard disables the port. After the timeout period expires, the switch re-enables the port. The timeout value can be 0 or a value ranging from 10 to 65535. With a value of 0, the port remains disabled until it is manually re-enabled. The default Timeout value is 60 seconds. |
Status |
Displays the SLPP Guard status for the port. |
TimerCount |
Indicates the time, in seconds, that elapses after SLPP Guard disables a port. When the TimerCount value equals the Timeout value, the switch re-enables the port. |
