Use the following procedure to display Intermediate-System-to-Intermediate-System (IS-IS) system statistics.
- Click Stats.
- Click the System Stats tab.
Use the data in the following table to use the System Stats tab.
Name |
Description |
CorrLSPs |
Indicates the number of corrupted in-memory link-state packets (LSPs) detected. LSPs received from the wire with a bad checksum are silently dropped and not counted. |
AuthFails |
Indicates the number of authentication key failures recognized by this Intermediate System. |
LSPDbaseOloads |
Indicates the number of times the LSP database has become overloaded. |
ManAddrDropFromAreas |
Indicates the number of times a manual address has been dropped from the area. |
AttmptToExMaxSeqNums |
Indicates the number of times the IS has attempted to exceed the maximum sequence number. |
SeqNumSkips |
Indicates the number of times a sequence number skip has occurred. |
OwnLSPPurges |
Indicates the number of times a zero-aged copy of the system's own LSP is received from some other node. |
IDFieldLenMismatches |
Indicates the number of times a PDU is received with a different value for ID field length to that of the receiving system. |
PartChanges |
Indicates partition changes. |
AbsoluteValue |
Displays the counter value. |
Cumulative |
Displays the total value since you opened the Stats tab. |
Average/sec |
Displays the average value for each second. |
Minimum/sec |
Displays the minimum value for each second. |
Maximum/sec |
Displays the maximum value for each second. |
LastVal/sec |
Displays the last value for each second. |
