Use the show ip igmp mrdisc command to display information about the IGMP multicast discovery routes. The syntax for this command is as follows.
show ip igmp mrdisc [vrf WORD <0-16>] [vrfids WORD <0-512>]
This command is not supported on a node configured as the DvR Leaf within a DvR domain.
The following table shows the field descriptions for this command.
Field |
Description |
VLAN ID |
Indicates the VLAN ID. |
MRDISC |
Indicates the status of multicast router discovery. |
MAX ADV INTERVAL |
Indicates the maximum number (in seconds) between successive advertisements. |
MIN ADV INTERVAL |
Indicates the minimum number (in seconds) between successive advertisements. |
MAX INIT ADV INTERVAL |
Indicates the maximum number (in seconds) between successive initial advertisements. |
MAX INIT ADV |
Indicates the maximum number of initial multicast advertisements after initialization. |
NBR DEAD INTERVAL |
Indicates the multicast router discovery dead interval — the number of seconds the multicast route neighbors for the switch must wait before assuming that the multicast router is down. |
DISCOVERED RTR PORTS |
Indicates the ports discovered. |
