Enable the collection of IPv6 multicast route statistics.
These statistics are not related to the interface (port) statistics. Rather, the statistics are displayed based on multicast group classification. By default, collection of multicast route statistics is disabled.
Example:
Enable collection of IPv6 multicast route statistics:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#ipv6 mroute stats enable
View the IPv6 multicast route statistics:
Switch:1#show ipv6 mroute stats
Multicast Stats
Statistics : Enabled
View the statistics for the multicast group IP address FF05::1:
Switch#show ipv6 mroute stats FF05::1
Multicast Stats - GlobalRouter
GroupAddress SourceCounter IngressPackets IngressBytes AverageSize
ff05:0:0:0:0:0:0:1 1 1962750 2355300000 1200
View the statistics for multiple group IP addresses (up to a maximum of 10).
Switch#show ipv6 mroute stats FF05::1,FF05::2,FF05::3,FF05::4,FF05::5,FF05::6,FF05::7,FF05::8,FF05::9,FF05::a
ff05:0:0:0:0:0:0:1 1 2027508 2433009600 1200
ff05:0:0:0:0:0:0:2 1 2027507 2433008400 1200
ff05:0:0:0:0:0:0:3 1 2027507 2433008400 1200
ff05:0:0:0:0:0:0:4 1 2027507 2433008400 1200
ff05:0:0:0:0:0:0:5 1 2027507 2433008400 1200
ff05:0:0:0:0:0:0:6 1 2027505 2433006000 1200
ff05:0:0:0:0:0:0:7 1 2027505 2433006000 1200
ff05:0:0:0:0:0:0:8 1 2027505 2433006000 1200
ff05:0:0:0:0:0:0:9 1 2027505 2433006000 1200
ff05:0:0:0:0:0:0:a 1 2027505 2433006000 1200
Variable definitions
Use the data in the following table to use the show ipv6 mroute stats command
Variable |
Definition |
WORD<7-400> {Ipv6address[,Ipv6address][,...]} |
Specifies the multicast group IP address for which to display statistics. The group IP address is in one of the following formats: a single IP address or a series of IP addresses. You can specify a maximum of 10 groups. |
Job aid
The following table shows the field descriptions for viewing multicast route statistics.
Field |
Description |
GroupAddress |
Specifies the multicast group IP address for which to show statistics. |
SourceCounter |
Specifies the number of sources associated with the multicast route record. |
IngressPackets |
Specifies the number of packets received for the associated IP address. |
IngressBytes |
Specifies the number of bytes received for the associated IP address. |
AverageSize |
Specifies the average packet length for the associated group IP address. This information indicates only the ingress packet length and is calculated using the formula: ingress packet/ingress byte. |
