Perform this procedure to view information about an inserted USB device.
This information may not apply to your hardware model. For more information about your model features, see your hardware documentation.
- On the Device Physical View, select the Device.
- Click Chassis.
- Click the USB tab.
USB field descriptions
Use the data in the following table to use the USB tab.
Name |
Description |
SlotDescription |
Specifies the slot type information. |
VendorId |
Specifies the vendor ID for the inserted USB device. |
Manufacturer |
Specifies the manufacturer of the inserted USB device. |
ProductId |
Specifies the product ID of the inserted USB device. |
ProductName |
Specifies the product name of the inserted USB device. |
SerialNumber |
Specifies the serial number of the inserted USB device. |
Revision |
Specifies the release number of the inserted USB device. |
MaxCurrent |
Specifies the maximum power as defined by the specification for the inserted USB device. The units of measurement are milliamps. |
