Use the following procedure to enable Remote Monitoring (RMON) on an interface.
Enable RMON globally.
Enable RMON on VLAN 2:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#vlan rmon 2
Enable RMON on port 3/8:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface gigabitethernet 3/8 Switch:1(config-if)#rmon
Use the data in this table to use the vlan rmon command.
Variable |
Value |
<1-4059> |
Specifies the VLAN ID on which to configure RMON. |
