Use the show ip igmp snooping command to display the status of IGMP snoop. The syntax of this command is as follows.
show ip igmp snooping [vrf WORD <0-16>] [vrfids WORD <0-512>]
This command is not supported on a node configured as the DvR Leaf within the DvR domain.
The following table shows the field descriptions for this command.
Field |
Description |
IFINDEX |
Indicates the interface index number. |
SNOOP ENABLE |
Indicates the status of IGMP snoop. |
PROXY SNOOP ENABLE |
Indicates the status of IGMP proxy snoop. |
SSM SNOOP ENABLE |
Indicates the status of IGMP Source Specific Multicast (SSM) snoop. |
STATIC MROUTER PORTS |
Indicates the set of ports in this VLAN that provide connectivity to an IP multicast router. |
ACTIVE MROUTER PORTS |
Indicates the active ports. |
MROUTER EXPIRATION TIME |
Indicates the multicast querier router aging timeout in seconds. |
SNOOP QUERIER ENABLE |
Indicates if the IGMP Layer 2 Querier feature is enabled. |
SNOOP QUERIER ADDRESS |
Indicates the IP address of the IGMP Layer 2 querier. |
DYNAMIC DOWNGRADE VERSION |
Indicates if the switch downgrades the version of IGMP to handle older query messages. |
COMPATIBILITY MODE |
Indicates if IGMPv3 is compatible with IGMPv2 |
