Configure a port to accept tagged or untagged frames.
In the Device Physical View tab,
select a port.
In the navigation tree, expand
the following folders: .
Click General.
Click the VLAN tab.
To configure tagging on the
port, select the PerformTagging check box.
This setting applies to all VLANs associated with the port.
![Note](images/note.png)
If the check box is selected, tagging is enabled. All frames sent from
this port are tagged.
If the check box is cleared, tagging is disabled. The port does not send
tagged frames. The switch removes the tag before sending the frame out
of the port.
To discard tagged frames on a
port for which tagging is disabled, select DiscardTaggedFrames.
To discard untagged frames on a
port for which tagging is enabled, select DiscardUntaggedFrames.
To designate a default VLAN to
associate with a packet that does not match a policy-based VLAN, enter a VLAN ID
in the DefaultVLANId box or use the default VLAN 1.
Click Apply.
Click Close.
