You must first onboard the VOSS device. When zero touch connection establishes, IQ Agent is enabled, by default. Before IQ Agent is operational, you must first disable IQ Agent, configure the ExtremeCloud IQ IPv4 address or DNS name, and then reneable IQ Agent.
enable
configure terminal
application
no iqagent enable
iqagent server address WORD<1-255>
iqagent enable
Configure IQ Agent:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#application Switch:1(config-app)#no iqagent enable Switch:1(config-app)#iqagent server address hac.extremecloudiq.com Switch:1(config-app)#iqagent enable
Display default IQ Agent configuration:
Switch:1>show application iqagent
IQAgent Info
Agent Admin State : true
Agent Version : 0.2.7
Agent Oper State : disconnected
Server Address : hac.extremecloudiq.com
Server Address Origin : None
Proxy Address : 0.0.0.0
Proxy TCP Port : 0
Proxy Username :
