Use the following commands to display IGMP information.
enable
show ip igmp interface [gigabitethernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]}][vlan <1-4059>[vrf WORD<1–16>][vrfids WORD<0–512>]
Ensure that the output displays snoop-spb under MODE.
show ip igmp cache [vrf WORD<1–16>][vrfids WORD<0–512>]
show ip igmp group [count][group {A.B.C.D}][member-subnet {A.B.C.D/X}] [vrf WORD<1–16>][vrfids WORD<0–512>]
show ip igmp sender [count][group {A.B.C.D}][member-subnet {A.B.C.D/X}][vrf WORD<1–16>][vrfids WORD<0–512>]
show ip igmp snoop-trace [group {A.B.C.D}][source {A.B.C.D}][vrf WORD<1–16>][vrfids WORD<0–512>]
Switch:1#show ip igmp interface
Igmp Interface - GlobalRouter
QUERY OPER QUERY WRONG LASTMEM
IF INTVL STATUS VERS. VERS QUERIER MAXRSPT QUERY JOINS ROBUST QUERY MODE L2ISID
V100 125 activ 2 2 0.0.0.0 100 0 0 2 10 snoop-spb 1100
1 out of 1 entries displayed
Switch:(config)#show ip igmp interface vlan 2
Vlan Ip Igmp
VLAN QUERY QUERY ROBUST VERSION LAST PROXY SNOOP SSM UPnP FAST FAST
ID INTVL MAX MEMB SNOOP ENABLE SNOOP FILTER LEAVE LEAVE
RESP QUERY ENABLE ENABLE ENABLE ENABLE PORTS
2 125 100 2 2 10 false false false false false
VLAN SNOOP SNOOP DYNAMIC COMPATIBILITY EXPLICIT UPnP
ID QUERIER QUERIER DOWNGRADE MODE HOSTS FILTER
ENABLE ADDRESS VERSION TRACKING ADDRESS
2 false 0.0.0.0 enable disable disable 239.255.255.250/32
Switch:#enable
Switch:1(config)#show ip igmp interface vlan 1
2 125 100 2 2 10 false enable false enable false
Switch:1# show ip igmp sender
=============================================================================== IGMP Sender - GlobalRouter
=============================================================================== PORT/
GRPADDR IFINDEX MEMBER MLT STATE
233.252.0.1 Vlan 501 192.2.0.1 9/5 NOTFILTERED
233.252.0.2 Vlan 501 192.2.0.1 9/5 NOTFILTERED
233.252.0.3 Vlan 501 192.2.0.1 9/5 NOTFILTERED
233.252.0.4 Vlan 501 192.2.0.1 9/5 NOTFILTERED
233.252.0.5 Vlan 501 192.2.0.1 9/5 NOTFILTERED
233.252.0.6 Vlan 501 192.2.0.1 9/5 NOTFILTERED
233.252.0.7 Vlan 501 192.2.0.1 9/5 NOTFILTERED
233.252.0.8 Vlan 501 192.2.0.1 9/5 NOTFILTERED
233.252.0.9 Vlan 501 192.2.0.1 9/5 NOTFILTERED
233.252.0.10 Vlan 501 192.2.0.1 9/5 NOTFILTERED
10 out of 10 entries displayed
Switch:1# show ip igmp group
IGMP Group - GlobalRouter
GRPADDR INPORT MEMBER EXPIRATION TYPE
233.252.0.1 V501-9/16 192.2.0.1 204 Dynamic
233.252.0.2 V501-9/16 192.2.0.1 206 Dynamic
233.252.0.3 V501-9/16 192.2.0.1 206 Dynamic
233.252.0.4 V501-9/16 192.2.0.1 207 Dynamic
233.252.0.5 V501-9/16 192.2.0.1 204 Dynamic
233.252.0.6 V501-9/16 192.2.0.1 209 Dynamic
233.252.0.7 V501-9/16 192.2.0.1 206 Dynamic
233.252.0.8 V501-9/16 192.2.0.1 206 Dynamic
233.252.0.9 V501-9/16 192.2.0.1 211 Dynamic
233.252.0.10 V501-9/16 192.2.0.1 207 Dynamic
10 out of 10 group Receivers displayed
Total number of unique groups 10
PORT/
233.252.0.1 Vlan 501 192.2.0.1 spb NOTFILTERED
233.252.0.2 Vlan 501 192.2.0.1 spb NOTFILTERED
233.252.0.3 Vlan 501 192.2.0.1 spb NOTFILTERED
233.252.0.4 Vlan 501 192.2.0.1 spb NOTFILTERED
233.252.0.5 Vlan 501 192.2.0.1 spb NOTFILTERED
233.252.0.6 Vlan 501 192.2.0.1 spb NOTFILTERED
233.252.0.7 Vlan 501 192.2.0.1 spb NOTFILTERED
233.252.0.8 Vlan 501 192.2.0.1 spb NOTFILTERED
233.252.0.9 Vlan 501 192.2.0.1 spb NOTFILTERED
233.252.0.10 Vlan 501 192.2.0.1 spb NOTFILTERED
Switch:1# show ip igmp snoop-trace
Switch:1#show ip igmp snoop-trace
Snoop Trace - GlobalRouter
GROUP SOURCE IN IN OUT OUT TYPE
ADDRESS ADDRESS VLAN PORT VLAN PORT
233.252.0.1 192.2.0.1 501 spb 501 1/7,1/9 NETWORK
233.252.0.2 192.2.0.1 501 spb 501 1/7,1/9 NETWORK
233.252.0.3 192.2.0.1 501 spb 501 1/7,1/9 NETWORK
233.252.0.4 192.2.0.1 501 spb 501 1/7,1/9 NETWORK
233.252.0.5 192.2.0.1 501 spb 501 1/7,1/9 NETWORK
233.252.0.6 192.2.0.1 501 spb 501 1/7,1/9 NETWORK
233.252.0.7 192.2.0.1 501 spb 501 1/7,1/9 NETWORK
233.252.0.8 192.2.0.1 501 spb 501 1/7,1/9 NETWORK
233.252.0.9 192.2.0.1 501 spb 501 1/7,1/9 NETWORK
233.252.0.10 192.2.0.1 501 spb 501 1/7,1/9 NETWORK
