This procedure does not apply to VSP 4450 Series, VSP 8600 Series, or XA1400 Series.
Perform this procedure to enable Link Layer Discovery Protocol (LLDP) voice authentication of IP phones on a specific port. If the system detects a phone through LLDP, then “eapol voice lldp-auth” configuration is applied on the port that is connected to the phone.
If you run the no auto-sense enable convert-to-config command, the system preserves the LLDP authentication configuration.
You cannot perform this configuration on Auto-sense ports. Use Auto-sense LLDP authentication to apply LLDP authentication on all Auto-sense ports in the VOICE state.
Enabling LLDP voice authentication on a specific port:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface gigabitEthernet 1/2 Switch:1(config-if)#eapol voice lldp-auth
The following table defines parameters for the eapol voice command.
Variable |
Value |
lldp-auth |
Enables LLDP voice authentication of IP phones on the selected port. By default, LLDP authentication of IP phones is enabled on the switch. |
