Use the following procedure to display the SPB-PIM Gateway VLAN interface information.
Switch:1>show ip spb-pim-gw interface
Spb-pim-gw Interface - GlobalRouter
IF ADDR MASK JPINT HELLOINT OPSTATE ADMINSTATE
Vlan50 50.1.1.1 255.255.255.0 60 30 Disabled Enabled
Vlan123 123.1.1.1 255.255.255.0 60 30 Disabled Disabled
Vlan142 142.1.1.1 255.255.255.0 60 30 Enabled Enabled
Vlan400 100.1.1.2 255.255.255.0 60 30 Disabled Disabled
Total spb-pim-gw Interfaces Displayed 4/4
Variable definitions
The following table defines parameters for the show ip spb-pim-gw interface command.
Variable |
Value |
vlan-id |
The VLAN ID of an interface to display. |
