This procedure does not apply to VSP 8600 Series and XA1400 Series.
Enable IS-IS globally.
Perform this procedure to configure a global IS-IS authentication key for ports that are operating in Auto-sense mode.
Configuring simple authentication for IS-IS hello packets on Auto-sense ports:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#auto-sense isis hello-auth type simple key Secure
The following table defines parameters for the auto-sense isis hello-auth type command.
Variable |
Value |
{none|simple|hmac-md5|hmac-sha-256} |
Specifies the authentication type for IS-IS hello packets on Auto-sense ports:
The default authentication type is none. |
key WORD<1-16> |
Specifies the authentication key (password) used by the receiving router to verify the packet. |
key-id <1-255> |
Specifies the key ID. |
