VOSS User Guide Version 8.3
> RADIUS Vendor Specific Frame Format
Published June 2021
Getting Help
Providing Feedback
DHCP Client
OOB Management Instance
CLIP Management Instance
VLAN Management Instance
Configuring the date
Install a New Software Build
Removing a software build
Displaying local alarms
Displaying log files
View UBoot Version and Status
Configuring the logon banner
CLI show command reference
Basic switch configuration
Current Switch Configuration
CLI Settings
Ftp-access sessions
Hardware information
High Availability State
NTP server statistics
Power summary
Power management information
Slot power details
System Information
System status (detailed)
Telnet-access sessions
Users logged on
CPU Queue Statistics
CLI procedures
Viewing configurations
Image Upgrade
IPFIX Upgrade Considerations
Committing an upgrade
Deleting a software release
Viewing BGP configuration
Viewe Power Information
Configuring DHCP relay
Configuration Limitations
DvR Limitations
Viewing DvR backbone entries
Configuring a DvR solution
Fail Open VLAN
Fail Open I-SID
EAPoL configuration using CLI
Fabric Extend View in EFO
Displaying the IP unicast FIB
Displaying the unicast FIB
Displaying IS-IS adjacencies
Configuring IS-IS interfaces
Verifying SPBM operations
SPBM L2 VSN
SPBM Reference Architectures
SPBM IP shortcuts
Receiver joining a group
Configuring PIM-SM globally
Configuring PIM on a VLAN
Enabling PIM-SM globally
Enabling IPv6 PIM-SM globally
Enabling SSM globally
Enabling IPv6 SSM globally
MLD configuration using EDM
General show commands
Multicast route information
Multicast route next hop
Static source groups
VLAN port data
IGMP show commands
IGMP access
IGMP cache
IGMP group
IGMP interface
IGMP router-alert
IGMP sender
IGMP snoop
IGMP static and blocked ports
SSM map information
PIM show commands
PIM active RP
PIM bootstrap router
PIM interface
PIM mode
PIM neighbor
PIM route
PIM virtual neighbor
Static RP table
IPv6 PIM show commands
IPv6 PIM mode
IPv6 PIM neighbor
IPv6 PIM interface
Show IPv6 PIM route
IPv6 PIM active RP
IPv6 static RP table
IPv6 mroute next-hop
IPv6 mroute route
IPv6 mroute interface
Enabling an IPsec policy
Black hole static routes
Configuring Static Routes
Configuring a CLIP Interface
Creating IPv6 static routes
Configuring IPv6 globally
Neighbor discovery
Viewing tunnel interfaces
FHS deployment scenario
Configuring IP Source Guard
Revoke a License
Revoke a License
Configuring LACP on a port
Configuring LACP on a VLAN
Enabling CDP Mode on a Port
MACsec fundamentals
MACsec security modes
Viewing MACsec Status
Enable an MKA on a Port
Interoperability behaviors
MLT configuration examples
Viewing OSPFv3 Information
Viewing OSPF status
Creating OSPFv3 Area Ranges
Modifying an OSPFv3 interface
Power usage threshold
Power Savings Fundamentals
Outbound connections
SSH version 2
User key files
Generating user key files
Enabling urpf-mode boot flag
Configuring the SLA Mon Agent
Configuring BPDU Guard
Changing the MSDP peer status
Viewing peer information
Viewing the local SA cache
Viewing the foreign SA cache
Viewing the mesh group
Controller configuration
Enabling the Controller
Displaying foreign sources
Enabling the Gateway
Enabling the Gateway globally
Source Specific Multicast
Peer Mesh Group
Multi domain
SPB domain interconnect
Statistics
Viewing Statistics Using CLI
Viewing TCP Statistics
Display NIC Counters
Clear ACL Statistics
View ACE Statistics
Viewing MSTP Statistics
Viewing RSTP Statistics
Viewing RSTP Port Statistics
Viewing IP VRRPv3 Statistics
Viewing IPv4 ICMP Statistics
Clearing IPv6 Statistics
Viewing IPv6 ICMP Statistics
Viewing IPv6 OSPF Statistics
Clearing IPv6 OSPF Statistics
Viewing IPv6 VRRP Statistics
Viewing Statistics Using EDM
Displaying File Statistics
Viewing ACE Port Statistics
Viewing ACL Statistics
Clearing ACL Statistics
Viewing VRRP Statistics
Viewing RIP Statistics
Graphing IPv6 VRRP Statistics
Graphing IP VRRPv3 Statistics
System Access
System access fundamentals
Logging On to the System
Web interface passwords
Password Requirements
Enabling CLI access levels
Configure an Access Policy
Creating multiple CLI users
Deleting a username
Enabling enhanced secure mode
Configuring the reuse rule
Enable Access Levels
Configure the Logon Banner
Create an Access Policy
Enable an Access Policy
Creating Multiple Users
Modify User Passwords
Disable a User Account
Delete a User Account
Enable Enhanced Secure Mode
TACACS+ Fundamentals
TACACS+ Operation
TACACS+ Architecture
TACACS+ authentication
TACACS+ authorization
TACACS+ Accounting
TACACS+ Feature Limitations
Enabling TACACS+
Add a TACACS+ Server
Configure TACACS+ Globally
Traffic Filtering
QoS and filters
Access control lists
Access control entries
Operators
Attributes
Conflict and Precedence
Switched UNI ACL Filters
Traffic filter configuration
Creating an IPv4 ACL
Creating an IPv6 ACL
Associating VLANs with an ACL
Associating ports with an ACL
Renaming an ACL
Disabling an ACL
Deleting an ACL
Enable IPv6 Egress Filters
Configuring ACEs
Configure ACE actions
Configuring ARP ACEs
Configuring an Ethernet ACE
Configuring an IP ACE
Configuring an IPv6 ACE
Configuring a protocol ACE
Configure an ACE
Configure ACE Actions
Configuring ACE ARP entries
Configuring an ACE IP DSCP
Configuring ACE IP options
Configuring an ACE TCP flag
Advanced filter examples
Data Collection for an Outage
Network Configuration
Troubleshooting Fundamentals
Connectivity Problems
Routing Table Problems
Cable Connection Problems
Alarm Database
LED Indications of Problems
Connectivity Fault Management
CFM Fundamentals
Maintenance Domain (MD)
Maintenance Association (MA)
Fault Verification
LBM Message
L2 Ping
Fault Isolation
Link Trace Message
L2 Traceroute
L2 Tracetree
L2 Tracetree-fan
Layer 2 Tracemroute
Nodal MPs
Nodal B-VLAN MIPs with SMLT
CFM Configuration Using CLI
Autogenerated CFM
Configuring Explicit Mode CFM
Configuring CFM MD
Configuring CFM MA
Configuring CFM MEP
Triggering Linktrace (LTM)
Triggering a Layer 2 Ping
Trigger a Layer 2 Traceroute
Trigger a Layer 2 Tracetree
Trigger a Layer 2 Tracemroute
CFM Configuration Using EDM
Autogenerated CFM
Configuring Explicit CFM
Configure CFM MD
Configure CFM MA
Configure CFM MEP
Configure CFM Nodal MEP
Configure Layer 2 Ping
Initiate a Layer 2 Traceroute
Configure Layer 2 IP Ping
View Layer 2 IP Ping Results
Trigger a Loopback Test
Trigger Linktrace
View Linktrace Results
Configure a Layer 2 Tracetree
CFM Configuration Example
CFM Sample Output
Troubleshooting Overview
Debug Files
Flight Recorder
Port Mirroring
General Diagnostic Tools
Using CLI for Troubleshooting
Using Software Record Dumps
View and Delete Debug Files
Configuring Port Mirroring
Ping an IP Device
Run a Traceroute Test
Showing SNMP Logs
Configuring I-SID Monitoring
Flush Routing Tables by VLAN
Flush Routing Tables by Port
Configure Port Mirroring
Configure ACLs for Mirroring
Configure ACEs for Mirroring
Run a Ping Test
View Ping Results
View Ping Probe History
View Traceroute Results
View the Traceroute History
Configure I-SID Monitoring
General Troubleshooting
Hardware Troubleshooting
Layer 1 Troubleshooting
Layer 2 and 3 Troubleshooting
Troubleshooting BPDU Guard
Troubleshooting IPv6 VRRP
VRRP Transitions
Troubleshooting RSMLT
RSMLT Peers Not Up
Troubleshooting vIST Failure
Multicast Troubleshooting
Using PIM Debugging Commands
Troubleshooting Fabric Attach
Troubleshooting FAN Transit
Upper Layer Troubleshooting
Troubleshooting SNMP
SNMP Trap not Received
Troubleshooting DHCP
Troubleshooting DHCP Relay
Troubleshooting TACACS+
Unable to Log On Using SSH
Using BGP Debugging Commands
Traps Reference
Proprietary Traps
Standard Traps
VLACP Configuration using CLI
Configure VLACP on a port
VLACP Configuration using EDM
Enabling VLACP globally
Configure VLACP on a Port
VLAN Configuration
VLAN fundamentals
Port-based VLANs
Policy-based VLANs
VLAN tagging and port types
VLAN router interfaces
IP routing and VLANs
VLAN implementation
VLAN configuration rules
VLAN Feature Support
Supported NLB Topologies
VLAN loop prevention
Switched UNI Layer 3
VLAN configuration using CLI
Create a VLAN
Create a Private VLAN
Limit MAC Address Learning
Configure NLB support
Configuring SLPP
Viewing SLPP information
Configuring spoof detection
Viewing VLAN information
View Private VLAN Information
View Port-Level MAC Security
View NLB-Mode Information
VLAN Configuration using EDM
Viewing existing VLANs
Create a Port-Based VLAN
Creating a Private VLAN
Changing VLAN port membership
Creating a SPBM B-VLAN
Configure NLB Support
Configuring SLPP globally
Configuring the SLPP by VLAN
Configuring the SLPP by port
Configuring static forwarding
Configure Limit Learning
VRF Lite
VRF Lite Fundamentals
Management VRF
Management Router VRF
VRF Lite configuration rules
Create a VRF Instance
Create an IPv6 VPN Instance
Configuring a VRF instance
Viewing Statistics for a VRF
VRRP Fundamentals
Critical IP Address
VRRP and SMLT
VRRP Fast Hello Timers
VRRP guidelines
VRRP for IPv6
VRRPv3 guidelines
Showing VRRP information
Showing extended VLAN VRRP
Viewing VRRP information
VRRP configuration using EDM
Configuring VRRPv3 Checksum
VXLAN Gateway
VXLAN Gateway Fundamentals
VXLAN Gateway Licensing
VXLAN Modes
Configuring VXLAN Gateway
VXLAN Gateway show commands
Displaying VNID information
Configuring OVSDB Replication
Configuring a remote VTEP
Configuring a VNID
Configuring VNID endpoints
Configuring ELAN endpoints
Displaying the VTEP next hop
Configuring OVSDB globally
5520 Series
VSP 4450 Series
VSP 4900 Series
VSP 7200 Series
VSP 7400 Series
VSP 8000 Series
VSP 8600 Series
XA1400 Series
Interface Indexes
Port Interface Index
VLAN interface index
MLT interface index
Supported IEEE Standards
Supported RFCs
Quality of service
Network management
MIBs
Standard MIBs
Proprietary MIBs
ICMPv6 Type and Code
The following figure shows the frame format for RADIUS vendor specific attributes (VSA).
RADIUS vendor-specific frame format
