The TLS server selects the server certificate in the following order:
A certificate authority (CA)-signed certificate if the certificate is already present in the /intflash/.cert/ folder on the switch.
A self-signed certificate if the certificate is already present in the /intflash/.cert/ folder on the switch.
If the server certificates are not available, the TLS server generates a new self-signed certificate at startup and uses that by default. The self-signed certificate is available in /.intflash/.cert/.ssl. You can choose to use an online or offline CA-signed certificate, which will take precedence over the self-signed certificate.
For more information about SSL certificate manipulation, see Certificate Order Priority.
If a certificate is already present, you must confirm that it can be deleted before a new one is created.
After you create a certificate, the system logs one of the following INFO alarms:
New default Server Certificate and Key are generated and installed
Current Server Certificate and Key are installed
The default certificate key length for a certificate generated on the switch is 2,048 bits.
The ssl certificate [validity-period-in-days <30-3650>] command in this procedure does not require a system reboot.
The following table defines parameters for the ssl certificate command.
Variable |
Value |
validity-period-in-days <30-3650> |
Specifies an expiration time for the certificate. The default is 365 days. |
